Bronze Member Username: Biggyg9712Post Number: 51 Registered: Sep-05 | im thinking of getting 2 12'' kicker compvr's on ebay for $150...is there anyhting else i can get that will be better than those for around $150??? |
Silver Member Username: CenusHicksville, Ohio Usa Post Number: 477 Registered: Jan-05 | better as in louder or sq or build quality. for better sq, and build quality look into re re or se, and for better spl look into anything audiobahn. |
Bronze Member Username: Biggyg9712Post Number: 53 Registered: Sep-05 | will the re re's sound better overall, and what amp should i get to power the 2 12'' RE re's |
Gold Member Username: SouthernrebelMonroe, Louisiana USA Post Number: 1038 Registered: Mar-04 | better for $150? maybe the RE re12's ($77 each) would have better SQ...but for $150, CVR's are a great buy. (forget about audiobahn) |
Bronze Member Username: Biggyg9712Post Number: 55 Registered: Sep-05 | what amp should i get to power them, i was thinking the kx600.1 but its underpowering them a little bit, is there anyother better amp for around $230 |
Silver Member Username: Tdeaton1021Near Tampa, Florida USA Post Number: 901 Registered: Sep-04 | isnt there a kx800.2 ... you could bridge that amp.... or even just run one sub each channel.. |
Gold Member Username: SouthernrebelMonroe, Louisiana USA Post Number: 1041 Registered: Mar-04 | a kx600.1 would be a good amp for 2 CVR 12's...make sure you get the DVC 2ohm version though. that amps really puts out ~700wrms. |
Bronze Member Username: Biggyg9712Post Number: 57 Registered: Sep-05 | alright, thanks, and should i use a sealed or ported box for this setup? |
Gold Member Username: SouthernrebelMonroe, Louisiana USA Post Number: 1042 Registered: Mar-04 | if you have the room, i'd go w/ ported. (but then again, i'm a ported box freak...i build a new box bout ever 6 weeks...lol) if you want hard hitting punchy bass, go sealed if you want gut busting lows, go ported (big box, tuned low) |
Bronze Member Username: Biggyg9712Post Number: 58 Registered: Sep-05 | well i cant build box's at all, do u think you could look real quick on ebay, and tell me which one is good, both ported and sealed, thanks |
Bronze Member Username: Biggyg9712Post Number: 59 Registered: Sep-05 | is the kicker kx600.1 rated at 14.4 volts or not? |
Gold Member Username: SouthernrebelMonroe, Louisiana USA Post Number: 1043 Registered: Mar-04 | i THINK its rated at 13.8V. ebay boxes are real "iffy" it you know what i mean...most of the sellers dont even tell you what the box is tuned to. |
Bronze Member Username: Biggyg9712Post Number: 61 Registered: Sep-05 | is this one any good: http://cgi.ebay.com/KICKER-FOSGATE-COMP-VR-12-DUAL-SUB-SUBWOOFER-MDF-BOX_W0QQite mZ5809722178QQcategoryZ14945QQrdZ1QQcmdZViewItem or what about this: http://cgi.ebay.com/ONIX-NEW-12-DUAL-VENTED-SUB-BOX-ENCLOSURE-JL-AUDIO_W0QQitemZ 5810009650QQcategoryZ14945QQrdZ1QQcmdZViewItem or maybe this: http://cgi.ebay.com/DUAL-12-SUB-ENCLOSURE-4-CAR-AUDIO-STEREO-BEST-BOX-U_W0QQitem Z5810935201QQcategoryZ14945QQrdZ1QQcmdZViewItem |
Bronze Member Username: Biggyg9712Post Number: 62 Registered: Sep-05 | do any of these box's look good? |
Silver Member Username: Matt12490Benicia, California Post Number: 227 Registered: May-05 | On ebay you can get Eclipse 6123's they are $80 shipped and get pretty loud and great SQ. The kicker amp really puts out about 750wRMS... i read that somewhere |
Gold Member Username: Basshead86Ocala, FL USA Post Number: 1323 Registered: Aug-05 | "if you want hard hitting punchy bass, go sealed if you want gut busting lows, go ported (big box, tuned low)" i like that, it flows very nicely, but i think i could add to the new box philosophy. If you want hard hitting blows, go sealed. If you want gut-busting lows, go ported. If you want to blow off your clothes, go bandpass. lol i'm really hyper!! |
Gold Member Username: SouthernrebelMonroe, Louisiana USA Post Number: 1045 Registered: Mar-04 | muddy...lay off that caffine |
Gold Member Username: SouthernrebelMonroe, Louisiana USA Post Number: 1046 Registered: Mar-04 | for the loudest of all...build a WALL. wow...i need some sleep. lol |
