My amp + subs
Username: Synargy
i have 2 10" MTX road thunder subs that have a resistnave of 4 ohms and RMS is 125 watts. i have one 300 watt pyramid amp with these dimensions
Description
Four Channel Amplification
4 x 75 Watts Total Output
Variable Gain Control
Accepts High or Low Impedance Inputs
Gold Plated RCA Inputs
High Level MOLEX Input
Output Impedance: 4-8 Ohms
Easy Access Speaker Connections
Remote Turn On/ Off
Thermal/Short Circuit/Overload Protection
Heavy Duty Aluminum Alloy Heatsink
Power On LED Indicator
Frequency Response: 20-30k Hz
S/N Ratio: >85dB
Dimensions: 2''H x 7.9''W x 8''L
will it be enough. (i am also powering 4 speakers)
Need to Register?
Forgot Password?
Enable HTML code in message
