If thats the case, almost any 8 inch sub would work as an 8 inch midbass.
Mine have a frequency range of 35hz-1000hz.
The reason I ask, is that some are labled subwoofer and others are labled midbass and I was wondering what the difference between the 2 drivers being that they are labled differently.
That is best in a car if you have the midbasses to do it with. The lower the x-over of the midbass, the better the sub will transition with them and keep the bass upfront.
VW
