hey i was wondering which subs i should get 2 12" alpine sws subs or 2 rokcford fosgate 12" P2 subs? there is 200rms total watt diff between them. i want the one which is good sound and also durabale as well as hard hittting bass.
i think they are about the same. they will sound about the same just depends on your amp setup, the impedence of the subs and how much power you have. what amp are you running
you guys make it sound like the type s is better then the rockford. its not. i think the rockford is just as good as the alpine if not better. the alpines will be no louder, and sound no better. im sick of people playing the brand game. yeah rockford may not be the best company but they are not the worst. and that goes the same for alpine, except the decks. and since you guys are just on entry level stuff there isnt goin go be much of a difcferece. go with what your budget allows.
Rockford is garbage I had a 600 watt amp, that thing could NOT keep up barely able to play for 30 mins without shutting off...just my experience anyways!
