New member Username: BilletxterraMiami, Fl Usa Post Number: 1 Registered: Sep-05 | i have two comp vr 15's connected 2/ohm with a memphis 1000D i currently hit 149.5db but it still doesn't feel loud enough. i wanna get one more but don't know what amp 2 get. now price limit just whant crazy bass |
Silver Member Username: Audiobass10Cape Coral, FL United States Post Number: 209 Registered: Jul-05 | what mic? mic location? |
New member Username: BilletxterraMiami, Fl Usa Post Number: 2 Registered: Sep-05 | don't know the mike it was at a local comp. but it was up above the dash near the winshield |
Silver Member Username: Tdeaton1021Near Tampa, Florida USA Post Number: 895 Registered: Sep-04 | i highly down you hit 149.5 with a TL mic. 149.5 ... theres no way you want to listen to that daily and say its not loud enough... |
New member Username: BilletxterraMiami, Fl Usa Post Number: 3 Registered: Sep-05 | i have proof but the pics i got don't wanna upload? You wanna see go to www.cardomain.com/ride/822962 but back to what amp to put the comp vr 15 hold 500watts RMS each |
Silver Member Username: Tdeaton1021Near Tampa, Florida USA Post Number: 896 Registered: Sep-04 | if you were running 2 15inch cvrs the whole time then how did u get 142 in one comp and 149.5 in anohter... 142-145 sounds right for those subs.... actually 145 sounds REAL good for sealed.... |
New member Username: BilletxterraMiami, Fl Usa Post Number: 5 Registered: Sep-05 | FROM WHAT I'VE LEARNED IS THE SONGS MAKE THE DIFFERENCE (BELEIVE IT OR NOT) |
Bronze Member Username: SlimjimCaro, MI US Post Number: 28 Registered: Mar-05 | listen to bass tracks on your system and find one that seems louder than all the other tracks. Do your testing with this single track so you have a better idea of what your really hitting. |
Bronze Member Username: SlimjimCaro, MI US Post Number: 29 Registered: Mar-05 | listen to bass tracks on your system and find one that seems louder than all the other tracks. Do your testing with this single track so you have a better idea of what your really hitting. |
New member Username: BilletxterraMiami, Fl Usa Post Number: 6 Registered: Sep-05 | THANKS BUT ANYONE NOW WHAT AMP TO USE FOR 3 KICKER COMP VR 15 AT 2/OHM W/ 500W RMS EACH |
Gold Member Username: SouthernrebelMonroe, Louisiana USA Post Number: 1032 Registered: Mar-04 | Christopher, from what i seen on that splstats.com site...they use an old AC mic. did the mic they used to measure your SPL look like a white stick about 9-10" long? where did they place the mic? where you allowed to open your doors or roll down windows? Xterra's can get loud pretty easily...i have seen one do 146 on the TL legal w/ 2 JL w6v2 12's. Your #'s are nice for a sealed enclosure, even if it is on the AC. I would suggest building a ported box for those CVRs before you got new subs. Old AC mics, depending on how long its been since their last calibration, can be 3-5db off from the new TL. |
Gold Member Username: SouthernrebelMonroe, Louisiana USA Post Number: 1033 Registered: Mar-04 | are those CVR's dvc 4ohm or dvc 2ohm? if they are dvc 4ohm, that memphis you have is a great match. oh...and by the way, unless i read it incorrectly your site says you are runnin 2 memphis class d amps. you sure that amp on your mids and highs isnt a class A/B? |
New member Username: BilletxterraMiami, Fl Usa Post Number: 8 Registered: Sep-05 | TO BE HONNEST FROM WHAT I REMEMBER IT WAS A BOX METER THAT LOOKED LIKE A DJ AMP. BUT IF YOU GO BACK TO WWW.SPLSTATS.COM AND YOU LOOK AT THE WATTS DIVISION UNDER 951-1300 YOU'LL SEE MY WIFES NAME (CRISTY) WITH OUR LAST SCORE. |
New member Username: BilletxterraMiami, Fl Usa Post Number: 9 Registered: Sep-05 | THEY ARE DVC CONNECTED AT 2/OHM. YEAH THANKS FOR NOTICING THAT I GOTTA FIX IT THERE ARE TWO ONE D CLASS THE OTHER IS A/B |
New member Username: BilletxterraMiami, Fl Usa Post Number: 10 Registered: Sep-05 | HEY MARSHAL YOU GOTTA LOOK OUT HURICANE RITA MIGHT BE HEADED YOU WAY. IS EVERYTHING ALRIGHT IN LOUISIANA????? |
Gold Member Username: SouthernrebelMonroe, Louisiana USA Post Number: 1034 Registered: Mar-04 | i'm in northeastern louisian...i'm good. http://www.splstats.com/modules.php?name=News&file=categories&op=newindex&catid= 3 look at the pic in the top-right corner of that page...is that what the SPL mic looked like? |
Bronze Member Username: BilletxterraMiami, Fl Usa Post Number: 11 Registered: Sep-05 | YEAH IT MIGHT HAVE BEEN BUT THEY THROW SHOW HERE LIKE TWICE A MONTH I'LL CHECK IT OUT AGAIN. I WAS THINKING OF GETTING A KICKER 1200 BUT THEN I'LL BE UNDER POWERING THEM WHILE 2500 MIGHT BE A LITTLE TO MUCH POWER. WHAT DO YOU THINK??? |
Gold Member Username: SouthernrebelMonroe, Louisiana USA Post Number: 1036 Registered: Mar-04 | so you have DVC 2ohm CVR's wired in series-parrallel to give the amp a 2ohm load....right? if so, i would look at a something along the lines of a jbl bp1200.1 or RF 1000bd. both put out full power at 2ohms. |
Bronze Member Username: BilletxterraMiami, Fl Usa Post Number: 12 Registered: Sep-05 | YOU THINK THAT 1200 WILL PUSH 3 15'S JUST RIGHT???? |
54321 Unregistered guest | would you recommended the kicker 15s becuase im about to get them |
