Recomended clearance: driver to enclosure wall
Username: A3forme
Post Number: 410
What's the recomended distance between the sub and box, sorry I forget.... total depth of box is 8 inches, mounting depth is 6 1/4 "
Username: A3forme
Post Number: 418
anyone?
Username: Southernrebel
Monroe, Louisiana USA
Post Number: 1029
your good
Username: Carguy
Post Number: 4324
Around 3".
Username: A3forme
Post Number: 419
So then I'm cutting it too close? It's a sealed 1 cu ft box for a single 12 and a PG sub I have to put in a on old beater. But if it won't work I may have to figure something else out.
Username: Kd7nfr
Montpelier, ID United States
Post Number: 837
Yea, that's cutting it close. I usually give it at least 5". My current setup has about 10", and they barely get warm to the touch after some seriouse cranking.
Username: Carguy
Post Number: 4332
A proper enclosure could make or break a sub. Why would you waste time and money on an old beater?
That's like putting in a turbo charger in your car and then downgrading the tires to golfcart wheels.
