High SQ subs
Username: Sarcastic
Great Bend, Kansas USA
Howdy, I recently purchased 2 Memphis 16-PRD 1000.1 amps. Little did I realize there are few subs that can handle 1000rms by themselves and be bridged down to 1ohm. I have a small trunk in my 95 eclipse and a fiberglass enclosure is out of the question. I would like to use both amps but only enough room for 2 subs. I do not want SPL subs I spent 1400 for the highs in my car and do not want to drown them out with low SQ bass. What I need help with is. What is the highest SQ 10in sub out there that is 2ohm dvc. I am looking at RF Power Stage 2 T210D2 and that's about all I have found. Has anyone used, or heard these subs? I want tight and clear bass. Thanks
Paul
Username: Basshead86
Ocala, FL USA
Post Number: 1244
you should get an Imaged Dynamics IDMAX, they come in Dual 2 and Dual 4, they handle 1000wRMS,a are comparable to the JLW7 in SQ.
http://imagedynamicsusa.com/products_page.php?id=idmax&type=sub
Ocala, FL USA
Post Number: 1245
*you should get an Image Dynamics IDMAX, they come in Dual 2 and Dual 4, they handle 1000wRMS,and are comparable to the JLW7 in SQ.*
fixed some typos
Username: A3forme
Post Number: 408
Definately a great SQ sub. Don't have personal experience with the 10s only 12s. I'm sure they're just as good. As good as they sound w/ 1000W to them, they are going to be loud and hit.
Username: Sarcastic
Thanks alot for your help, I will look into them.
Paul
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 98
If you can spend that much on highs you might want to look into JL Audio W7 or SoundSplinters RL-p both sound great.
Username: Mikechec9
Http://www.cardomain.c...
Post Number: 992
brahma
