Element design system
Username: Monkey_man
Post Number: 305
I was just curious about these drivers. If i were to get two 13Ov.2 Subwoofers how would they sound? Well i mean compared to let's say one idmax. I would be getting the nine.1 to power them or for the idmax i would be powering it with 800watts of mb quart power.
Username: Basshead86
Ocala, FL USA
Post Number: 1328
the 2 130v.2 subs would be louder, but i am not certain about which would have better SQ, b/c i am not familiar with ED subs.
Post Number: 306
Thanks for your input. The drivers seem like they have great sq. I was just thinking of using my raa2400 for the front speakers which will hopefully be mb quart. Then going with that ed setup. Other wise, i will be using that amp to run one idmax and purchasing the 4 channel amp from mb quart for the front speakers and back speakers. What do ya think? Which setup will be louder or have better sq?
Ocala, FL USA
Post Number: 1339
i would go with IDMAX, b/c i plan on getting one, and don't particularly need very loud bass.:-)
i would go with the MB Quart speakers, and get rid of the rear fill, and spend the money you save on buying rear speakers on a good amp and even better MB Quarts.:-)
Ocala, FL USA
Post Number: 1340
and spend the money you save on not buying rear speakers on a good amp and even better MB Quarts.
Post Number: 307
So my plan before was solid? But the only thing is, i don't think that it will be lour enough. I currently have two type e's hooked up and they are no where near loud enough.
Username: Mikechec9
Http://www.cardomain.c...
Post Number: 1004
http://forum.soundillusions.net/archive/index.php/t-48321.html
Post Number: 308
The only problem is...they don't sell avalanches ney more. I would like know how it compares to just one idmax. I want to know how much more spl the ed's have(i only listen to rap, a lil techno). I love sq but it is the top priority as long as the driver doesnt sound like a kicker when i get's loud.
Post Number: 309
Okay never mind that...how about one 160v.2 vs a idmax 12". Will the idmax get louder?
Post Number: 310
Any body??
Post Number: 311
Okay never mind. My friend was going to get an atlas but they are sold out. He wants to get a twelve for like 150 would a ed be good for him? he listens to old school rock and rap as well.
