Posted on will head units make my system louder |
Gold Member Username: Illuminator
Post Number: 1910 Registered: Apr-05
Posted on Of course...they have a higher RMS output than the factory unit and can filter which frequencies go to the speakers so they don't distort. But aftermarket speakers are also a great idea if you upgrade your headunit and you're looking to make it loud. |
Silver Member Username: Tdisanto
Post Number: 173 Registered: Sep-05
Posted on The head unit will deliver much much cleaner power than the factory radio. |
