HU's with subwoofer preouts
WC
Are HU's that have a subwoofer preout better that HU's that dont. Alos what is the difference with HU with sub prout and non sub preouts.
Username: Jurasskick
Post Number: 10
Better in that you don't usaully have to mess with crossovers to split your signal to sub amps or set frequency ranges. Usually with sub pre-outs the HU has a built in crossover and a separate level control. From the deck straight into your sub amps. Less fuss.
Username: Glasswolf
Wisteria, Lane USA
Post Number: 10400
head units with sub preouts have built in crossovers to split up frequencies for just the subs and just the mids/tweeters.. in case your amplifiers don't offer filters.
these units also give you the choice of up to 6 channels of amplification without the need for an external active crossover.
better option in my opinion.
WC
Aight cool than thanx.
