PLS HELP ME
Username: Wetbo529
Hi i have two 10inch jl audio subs. recently i found that the one on the right starting like rattling and then it just got worse and i dont kno why. i checked for faulty wiring and nothing. can somone pls just tell me if i should buy a new one or now cause im so lost and tired of a terrible noise coming from the back instead of a beautiful bang
Username: Thigpen
Post Number: 26
is there some place that sells jl audio around you? im actually a pretty big scrub when it comes to car audio but id been looking at jl audios alot and ive seen a few ppl go in and talk with the ppl at the store about similar problems so you could try that or just calling them to figure out if you could fix it and how much it would cost
Username: Glasswolf
Wisteria, Lane USA
Post Number: 10385
rattling would indicate a blown sub.
probably caused by a clipped amplifier
