Which has more spl 2 12s or 1 15?
James Riley
which would have more spl 2 12s or 1 15 with the same amount of power??
Username: Audiobass10
Cape Coral, FL United States
Post Number: 205
That's all dependant on the install/products used.
Username: Rovin
Trinidad & T...
Post Number: 624
If its the same brand & same rms - then the usual answer is 2 12s due to more cone area & more air being moved .
Username: Taylor17
Kopperl, Texas
Post Number: 2877
More than likely the 2 12's, because of the surface area, but I wouldn't be willing to bet my system on that or anything.:-)
70003
I just went from 2 12" Jl audio to 1 15" Diamond audio and the same amp and 15" pounds quit abit hard than the 2 12's. I still have another 15" Diamond audio to install when I buy a bigger amp.
Username: Rovin
Trinidad & T...
Post Number: 633
Can't argue with your findings , but thats comparing 2 different brands & wattage altogether .
Username: Insearchofbass
Post Number: 3487
its also two different enclosures which can make a difference also
