2ohm or 1ohm??
Username: 02taco
Sville, Ga USA
Post Number: 37
hey, i'm wiring them as we speak so i need to know. i've got two 2ohm DVC subs, i need to know the best way i should wire them and what load would be best??
Username: Tdisanto
Post Number: 37
what kind of amp are you using? Is it 2ohm or 1 ohm stable.
You could wire each pair of coils in series giving each sub a 4 ohm impedance, then wire both subs in parallel to achieve a 2 ohm load. Just make sure your amp can take a two ohm load.
Username: Taylor17
Kopperl, Texas
Post Number: 2879
Yup, we need to know what amp you're using first.
