Saturday, September 17, 2005 - 06:42 GMT My friend just upgraded his 12W7 to XXX's and was going to give me his box, because I just got an Alpine Type X. the box is vented and this is my first sub. Will this box work.
Username: Johntheguy Post Number: 9 Registered: Aug-05
Monday, September 19, 2005 - 06:15 GMT no. ported boxes are made for a specific sub
Monday, September 19, 2005 - 19:52 GMT that's not entirely true. a box is deisgned for a specific sub but that does not mean many diffenent subs wont work and sound good...
Username: Taylor17 Kopperl,
Texas
Post Number: 2888 Registered: Jan-05
Monday, September 19, 2005 - 20:53 GMT It all depends on the size of the box, and how much power you're going to give the sub. Knowing what the box is tuned to wouldn't hurt either.
Username: Secretsoundz St. Paul,
Mn
Post Number: 26 Registered: Aug-05
Monday, September 19, 2005 - 20:53 GMT Your type X has a Qts of .64 Sealed would be optimal for it.
Username: Kd7nfr Montpelier,
ID
United States
Post Number: 817 Registered: Apr-05
Monday, September 19, 2005 - 23:16 GMT Yea, those subs are best sealed. But it wouldn't hurt to hook it up and see how it sounds.
Username: Southernrebel Monroe,
Louisiana
Post Number: 1019 Registered: Mar-04
Monday, September 19, 2005 - 23:22 GMT an alpine type-X 12" isnt going to fit in a box built for a 12w7, unless you build a new baffle. the cut-out diameter of the hole is much bigger for the w7 than for the type-x.
