Anonymous | I got 3 12WOs. 12Ohm. I need a amp thats got about 350-375w RMS; because Im gonna wire em up parallel to =4 ohms. I wanted a JL, but nothing meets anything. What are some nice alternatives? Does it need to be Mono? I dont really wanna spend over 350. Thanks. |
Silver Member Username: MixneffectOrangevale, Ca. USA Post Number: 356 Registered: Apr-05 | You have two choices; mono amp 375 rms @ 4 ohms or, a multi channel amp that delivers 125 rms @ 12 ohms http://cgi.ebay.com/NEW-05-ALPINE-MRD-M605-V12-Mono-Sub-Amp-Amplifier_W0QQitemZ5 810302529QQcategoryZ79825QQssPageNameZWDVWQQrdZ1QQcmdZViewItem http://cgi.ebay.com/JL-Audio-500-1-Monoblock-CLASS-D-AMP-NEW-2005-MODEL-HOT_W0QQ itemZ5810274076QQcategoryZ18797QQrdZ1QQcmdZViewItem http://cgi.ebay.com/XTANT-A6001T-MONO-AMPLIFIER-600W-SUB-WOOFER-AMP-NEW-05_W0QQi temZ5809644465QQcategoryZ64573QQssPageNameZWDVWQQrdZ1QQcmdZViewItem http://cgi.ebay.com/HIFONICS-BX1500D-Class-D-1500W-Amp-NEW-2004-1500-WATT_W0QQit emZ5810056164QQcategoryZ18797QQrdZ1QQcmdZViewItem http://cgi.ebay.com/MEMPHIS-1000-WATT-CLASS-D-MONO-AMPLIFER-16-PRD-1000-1_W0QQit emZ5810187008QQcategoryZ18797QQssPageNameZWDVWQQrdZ1QQcmdZViewItem http://cgi.ebay.com/PRECISION-POWER-PPI-DCX1000-1-DCX-1000-1-AMP-AMPLIFER_W0QQit emZ5809587244QQcategoryZ18797QQssPageNameZWDVWQQrdZ1QQcmdZViewItem Remember, most speakers are blown due to UNDERAMPLIFICATION, no overamplification. Just be carefull with the volume. |
Anonymous | Well I'd rather go with the Mono. I'm not to fond of Precision Power, Memphis, Hifonics. I want a nice brand. I dont wanna go through E-bay. |
Anonymous | http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=415 http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=599 http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=2461 I need 375w RMS. Which one of these is the best for 3 12wo's? Im guessing the Zapco? |
Silver Member Username: MixneffectOrangevale, Ca. USA Post Number: 358 Registered: Apr-05 | Yeah, the zapco is the better choice here. I just gave some options. You may choose to buy them from anywhere you like. I just offered a response to your inquiry, thats all. |
