Need helpin pickin out an amp for my 12" L7's.
hey i have a 91 accord ex coupe.... i just ordered 2 12" L7 4ohm solo barics.i was lookin at gettin the Audiobahn A8000T which is, 400 watts RMS x 1 at 4 ohms, 800 watts RMS x 1 at 2 ohms... and if i got that id eventually get a second 1 for the other sub.. the sub specs are 700rms/1,500peak so is it a way to wire a single 4ohm sub to a mono amp at 2ohms so that, that amp pushs 800watts to that one 12? and if so that means it would have 800 watts going to it, so would it bust or no since the 1,500watt peak?
Username: James_g
TN
Post Number: 227
Are the subs dual voice coil?
Mike Roffle
http://www.crutchfield.com/S-SVgCBiVU79Q/cgi-bin/ProdView.asp?g=520&I=2064S12L7 is the subs i ordered. http://www.crutchfield.com/S-SVgCBiVU79Q/cgi-bin/ProdView.asp?g=120&I=037A8000T / http://www.crutchfield.com/S-SVgCBiVU79Q/cgi-bin/ProdView.asp?g=120&I=113KAC9102 / are the amps i was looking at.. i wanted to get 1 and then when i got more money get a second.. but if i had a amp for each sub could i still bridge to 2ohms? and if so with the stats of those amps would my subs bust?
Username: James_g
TN
Post Number: 230
Those are DVC 4 ohm subs. Yeah, you can wire one of them to that amp at 2 ohms. You parallel the VCs which means wiring positive (+) to positive (+) and negative (-) to negative (-).
Mike Roffle
which amp's should i get the kenwoods or audiobahns? an will they bust my subs?
