jacobb Unregistered guest | i have 4 RE xxx 15"s 1600watts rms and 2500w peak what amps are recomended |
jacobb Unregistered guest | anyone????????? |
Silver Member Username: UcfsaxmanOviedo/orlando, Fl Post Number: 134 Registered: May-05 | wow thats a lot of power are the subs dvc and what is the impedence(ohm load). if you have the money get 4 amps that do about 1200-1600 watts. Look into JL, Xtant, JBL maybe rockford fosgate. You want clean amps that will do their full advertised power. |
Silver Member Username: RovinTrinidad & T... Post Number: 613 Registered: Jul-05 | Talk about loud - WOW , hope your glass can take that spl & not fall out. What ride will the 4 15s go in - a van ? |
jacobb Unregistered guest | a chevy 20 van |
jacobb Unregistered guest | thanks 4 your help |
Silver Member Username: RovinTrinidad & T... Post Number: 619 Registered: Jul-05 | Other brands with that much power u can add to that above list are Zapco(damn they are expensive) , Kicker , Orion , Mmats , US Amps , Crossfire , Arc audio etc This site carries alot of these brands mentioned - www.woofersetc.com |
sterio2005 Unregistered guest | Holly snapp. Well id reccomend 2 amps actually Mono Channel 4000watts. I wouldnt want you going max and blowing anything like every cirucit in your car lol. |
