hey glasswolf jus yesterday i was listening to music and i saw my HU ulled out a little so i pushed it in and out of no where my HU and Eq Turned off hasnt turned back on but shows signs of life because i took out a cd i had in my radio people tell me it might be my ignition wire but i need some expert advice plz dont kno fi it might help but i have a 92 civic sedan
yup it's the switched power line. probably came loose or blew the fuse behind the head unit. you have constant power so the CD ejects, but you can't turn on the radio so switched power is gone. check the fuse box too that mayb e where the fuse blew.
i checked the fuse box which everything was fine then i checked behind the Hu everything fine im tryin to fix the switch power wire but not sure where to start lookin
