Does this look right????
greasedog
alright, my friend bought this amp awhile ago. its a clif designs, now i personally think its crap, but what do i know, i have no certifications in mobile technology. here is the link, will someone give some input on this amp??\ i have two infinity 12 dvc kappa perfect that i wanna run and he is going to let me borrow the amp.
http://www.avperfection.com/scripts/prodView.asp?idproduct=724
Username: Prankstar008
San Diego, CA USA
Post Number: 67
it looks ok..but if you notice it doesnt state what the 1 @ 4ohms RMS wattage is...only at 2 ohms...just an observation
Username: Glasswolf
Wisteria, Lane USA
Post Number: 10317
2 x 300 watts rms @ 4 ohm
2 x 450 watts rms @ 2 ohm
2 x 600 watts rms @ 1 ohm
1 x 1200 watts rms @ 2 ohm
if you think it's crap then go buy your own amplifier..
that's pretty simple.
