New member Username: Gsxr1000
Post Number: 2 Registered: Apr-05
Posted on DB25 male connector To Pansat JTAG plug Pin 2 ----------------> 100 ohm resistor ---------------> JTAG Pin 9 Pin 3 ----------------> 100 ohm resistor ---------------> JTAG Pin 11 Pin 4 ----------------> 100 ohm resistor ---------------> JTAG Pin 13 Pin 5 ----------------> 100 ohm resistor ---------------> JTAG Pin 19 Pin 13---------------> 100 ohm resistor ---------------> JTAG Pin 15 Pin 18~25---------------------------------------------------> Pansat GND What I need to know is the type of ribbon cable. There is a floppy ribbon cable and a IDE ribbon cable, which one is it? Plus, where is pin 1 located in both the parallel cable and ribbon cable? A layout of how cables are sorted according to their pins can help too. an example like this will help on both cables: pin1 pin2 pin8 pin3 pin10 pin4 pin9 pin5 pin7 pin6 *A LAYOUT OF THE PANSAT 2500A IS VERY HELPFUL* THANKS AGAIN.......... |
