DVB/FTA Unregistered guest | Has MyTheatre V3.26 + Patch along with some other Nagra2 functioning files. DVB/FTA FIles & Product Links Here --> http://www.seaside.ns.ca/~atyourservice/id44.htm |
Patcher Unregistered guest | Can't get Patch to work. Anyone have any success with it or could lead me to another one for MyTheatre V3.26 TIA ! |
DVB/FTA Unregistered guest | Pansat 251 slow ecm (09-13-05 ) is posted at above Link. All channels including adult,ppv and internationls are up. Both N1 and N2. using pansat 2500. File is said to be running well, (not a Clone Killer) but remember.... ** Use at own risk ** |
New member Username: Zuman37Post Number: 7 Registered: Mar-05 | Hornporn is back! Works on my 2500A. Fantasy freezes often. But other than that all channels available. |
Anonymous | is there a fix for cool@sat pro |
NewKeysHere Unregistered guest | For those that can Edit...these are the new Keys --> N 0001 10 B4ED24E3BCC18269E1B009C3C1D0C8A1 Key update: 14-09-2005 N 0101 10 B4ED24E3BCC18269E1B009C3C1D0C8A1 Key update: 14-09-2005 DVB cards are up now too ! ![]() |
Canche Unregistered guest | DVB/FTA Thanks for posting that website, my digiwave is running fine now, thanks again. ----> http://www.seaside.ns.ca/~atyourservice/id44.htm |
BMWXWE Unregistered guest | THANKS RUNNING GREAT!!!! |
Anonymous | if my pansat 2500a is dead do i need a jtag or are the files going to fix it. |
Dr. Ling Gus Unregistered guest | If the jtagless files put out by Blacklist didn't work on your receiver ... you will have to jtag first. Good Luck with it. My Pansat 2500a is up and running! P0RN and all ... due to the waver on the file *USE AT OWN RISK* be sure to cover your face when you get close to it in case it explodes. Blacklist said that YONO fixed it. So it probably won't intentionally fry your receiver. Guess the game is back on .... Thanks Guys! |
canche Unregistered guest | is anyone getting a HD signal problem on thier reciever for the digiwave? i think the bin from yesterday is not workin now. Any help would be great |
