New member Username: VashwoodPost Number: 3 Registered: Sep-05 | which 15'' sub diamond audio would be best for an all around music listener? plus what amp would be good to power it? |
Silver Member Username: RovinTrinidad & T... Post Number: 650 Registered: Jul-05 | Well their lowest model D3 = 200wrms & highest D9 = 1000wrms . So i'd say go midway with the 15" D6 = 500wrms so its not too loud or too little bit . U would like only 1 15" sub ??? if only 1 then this amp http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=2380 |
Silver Member Username: DisturbedpriestPost Number: 171 Registered: Jun-04 | If the 15 hits anything like the 10's god help you i have two diamond audio tdx 10s the new d9's they hit hard for tens. You might want to consider one tdx 12 and be happy. |
Silver Member Username: Mikechec9Http://www.cardomain.c... Post Number: 986 Registered: May-05 | D9 are great sql subs. |
