Toshiba TV picture problems
Hi, I'm hoping you can help me figure out a problem with a Toshiba projection TV I've got.
Whenever a really light shade of blue appears on the top third of the screen, green horizontal lines run though it. It's only on the one color, though, and I'm not sure if this is a settings problem or a problem with the TV that would need to be serviced. Any advice you can give would be great! Thanks!
picture intermittenly pulses light to dark
dlp from toshiba the worst ever after 45 days the lamp blew national backorder they tell me Its been a month with no lamp spent 3k for this crap dont buy toshiba customer service the worst ever how many lamps am i going to go through at 300 a pop buy the warranty bought at best buy
