New member Username: ChibagePost Number: 1 Registered: Jun-05 | Hi I recently purchased an HP AMD Athlon64 3200 512 mb RAM 2.2.Gh. My question concerns the Burning video onto DVDs. I have captured the video in MPEG2 format using Video Wave professional by Roxio. It wasn't a problem, and it amounted to about 2.8 gigs on the hard drive. Trying to burn it on the DVD using the burner that recognize DVD+R DVDs has been a nightmare. I went ahead and created the menus and titles, and clicked on Burn. Two bars appeared to be showing that it was burning. It says step 1 of 2, and then hangs up forever. It spoiled some of my blank DVDs. I end up just powering off the machine again and again, and I am so frustrated. Please help, and I am new in the DVD burning world. |
New member Username: Tap_mtGreat falls, Mt Usa Post Number: 4 Registered: Jul-05 | I'd like to make copies of home movies I recorded to DVD-R from VHS. I have Dell dimension DIM4500 Intel® Pentium ® 4 CPU 1.80 GHz, 1.79 GHz, 640 MB of Ram computer with Microsoft Windows XP, home edition, version 2002, service pack 2. Ihave PC Friendly DVD player, 1998. I have the CD/DVD rom drive, 3 1/2 slot and an empty slot. Can anyone recommend what DVD burning program to buy. External or internal, I don't care. I'd like one not to complicated. Thanks |
Gold Member Username: SamijubalPost Number: 1624 Registered: Jul-04 | No need to buy anything. Use DVD Decrypter, ISO read, then ISO write. You need a burner if you don't have one. Newegg.com sells NEC burners pretty cheap, they read DVD-R very fast and burn excellent. |
Gold Member Username: IlluminatorUSA Post Number: 1613 Registered: Apr-05 | www.dvdsanta.com |
Silver Member Username: Bassfreak596Post Number: 127 Registered: Oct-04 | that was quick ! |
Bronze Member Username: Ping_mePost Number: 20 Registered: Sep-05 | she has a burner! Dvd decrpter and dvdshrink |
