Bronze Member Username: Biggyg9712
Post Number: 21 Registered: Sep-05
Posted on im thinking of buying an eclipse 12'' aluminum subwoofer and it runs 450 watts rms and 900 watts peak. what amp should i get to power this? |
Silver Member Username: Matt12490
Benicia,
California
Post Number: 194 Registered: May-05
Posted on What are the voice coil configurations? |
Post Number: 23 Registered: Sep-05
Posted on i think 4 ohm dvc |
Post Number: 24 Registered: Sep-05
Posted on nvm sorry..its not dvc 4 ohm its dvc 2 ohm |
Post Number: 26 Registered: Sep-05
Posted on bump |
Silver Member Username: A3forme
Post Number: 392 Registered: Sep-04
Posted on These subs are typically under-rated. For the 2ohm DVC you can go with an amp that puts out 500-600w RMS at 1 or 4 ohms. Maybe a PG Xenon 600.1 or JL 500/1, these will both opperate at 1-4ohms. MTX 1501D might also work. If you went with the 4ohm DVC your options would be much better and probably cheaper.... |
Post Number: 394 Registered: Sep-04
Posted on Doh..sorry forgetting about 2 channel amps. Either way you should be able to find something that works |
Gold Member Username: James1115
Wilton,
Ct
Post Number: 3926 Registered: Dec-04
Posted on the JL isnt 1ohm stable but it will work well at 4ohms. How much do you want to spend? lets start there. |
Post Number: 397 Registered: Sep-04
Posted on Sorry, your right. 1.5 ohm |
