Hey, I just got a new record player that I'm really excited about. I started using it the second I got it. However, whenever I play a song near the beggining or the outter edge of the record it plays really slow, like I changed the tempo. However if I play a song farther along on the record (or closer to the middle) then it plays fine. It looks like the needle is pressing too hard on teh record which slows it down which makes the song play slower. Any idea on how to fix this or am I stuck this way? Thanks for any help!
You're not stuck this way, byt the table will need adjustment if your diagnosis is correct. Take the table and your receipt back to where you purchased the table and have a technician do the adjustment.
