ok well this is what i have hooked up for my deck to work..but its not working..so hers what i have hooked up..i have the red wire from inside the car..and the red wire from the head unit(my deck)...and the yellow wire from inside the car..and the yellow wire from my deck...and a power wire from the battery to all that that i just said...and its like not getting power somehow..and i tryed the fuses and it doesnt work...somebody help please.........
you NEVER match colors. You've probably already fried the new radio. you should have just bought a wiring harness adapter instead of cutting wires. Now that you've cut them though, try going to the12volt.com and using the installer database of vehicle color wiring codes to look up your car and see which wires you should have used.
smell the deck, then check fuse on radio, then if you have no power supply, twist red&yellow together, then use battery from car to test the radio to see if it powers up,... touch the ground to ground and the twisted red/yellow to power...see what you get.
At this point, if he burned the radio, i would eliminate it first, then go to 12volt and get the wiring diagram for the car. sucks to wire everything back up and radio is bad.
