Jorge Villalobos Unregistered guest | I have a scion xB and the cheapest HO alt I can find is $550. A little more than I want to spend on an alt. What is the most wattage you think I could get away with without putting in a new alt? PS.. if anyone knows where I can maybe find a cheaper alt for my car for less, post that too. Thx. |
Silver Member Username: James_gTN Post Number: 204 Registered: Jul-05 | Did you contact Nathan at Excessive Amperage? |
Jorge Villalobos Unregistered guest | I emailed him a week and a half ago, no response |
Platinum Member Username: GlasswolfWisteria, Lane USA Post Number: 10359 Registered: Dec-03 | http://www.wickedcases.com/caraudio/capacitors.html http://www.wickedcases.com/caraudio/charging.html http://www.betteraudio.com/geolemon/newmain/battcapalt/ http://www.bcae1.com/charging.htm http://www.bcae1.com/chargin2.htm |
