Ultimate SQ 5.25 or 5x7 coax setup for my Ford
Username: Fordfanatic
Toronto, ON
Hi there
I'm currently running Mclass 5x7 and Diamond D651i across the 4 corners, but I just received a solid bonus from work and would like to start an upgrade. My truck is leased and they frown on cutting the truck, so components are out. I can spend $1500 for the speaker upgrade(either the fronts or all 4 corners) so I can afford something decent. A friend suggested Morels, but I'm open. I'm in Canada, so I might have to resort to ebay or other internet order sites.
Thanks
Username: Glasswolf
Wisteria, Lane USA
Post Number: 10040
Morel, DLS, Rainbow, DynAudio, SEAS, Scanspeak, Focal.. any of them are excellent choices.
get front 6.5" separates.
fiberglass kick pods to front mount them for the best imaging (no cutting, and you can pay someone to do the glass work)
get an amplifier to drive the speakers.
forget rears unless you really feel a need to have them.
concentrate on front stage and subs.
Username: Jonathan_f
GA USA
Post Number: 4715
If you want just a pop in 5x7 solution, look at the Jl Audio XR coaxials, not too many brands offer 5x7s that are high end.
