Please help: What other brand cases will fit my PalmZire 31???
Hollym
None of the Palm cases meet my needs. I know there are other PDAs the same size & other cases that would be compatible, but can't tell online.
I want a SLIM leather case w/ belt clip, easy access (NOT zipper pouch), a couple slots for exp cards, and under $20.00ish.
I truly appreciate your good advice.
Holly
Don't know if you've found anything yet but I've had a Palm M505 for about 5 years and bought a case called a 'Slipper' from www.ebcases.com which does a great job of protecting the PDA, stores 2 cards without them touching the screen and flips open for ease of use. It costs $35 but is far better than any others I came across (& I used to source loads of cases in my old job).
Need to Register?
Forgot Password?
Enable HTML code in message
