dont't know, thank you fox, i thoght that, since it was working, i only took the box to a guy to "fix it", and i assumed it will still be working as it was,thank you thank you!!!
little ceasar
do i need a new program or...something?
MapIe Leech
you have to configure ur antenna settings first press menu then antenna settings
then sat 1 ( 110 )---->port A sat 2 ( 119 )---->port B
LK
IF U LOST the 110...then check the disque switch (as above)...or try reversing them and see what happens..or either bad cable to switch,connection or LNB...also many times jthe switch is bad...
If U must, disconnect the switch and run each cable one at a time from LNB directly to receiver..that'll tell U if its the switch is bad...and also that will let U know if the LNB's and cable and connections are good too..
and always do a scan and then a reboot last (BACK of receiver,power off.wait 1 minute,power on,turn to channel 300
little ceasar
maple leech........ lk.......thank you thank you!!!!! is fixed thanks to you guys!!!!!! thank you.......
LK
so tell us what was wrong so others here can learn!
