Archive through September 09, 2005
LK
How do U know U have Bev,not Dishnet?...if thats true then, of course U MUST realign the roof dish!...
"scrambled channels" fix many times is a reboot/reset of receiver....BACK of receiver,power off,wait 1 minute,power on,turn to channels 300 or a known working channels..
LK
"scrambled channels" fix many times is a reboot/reset of receiver....BACK of receiver,power off,wait 1 minute,power on,turn to channel 300 or a known working channel..
Username: Lazeress
Can any one help ???????
I have a fortec life time Ultra And have put the new Keys in but all i get is a black screen and scrambled or bad channel what can I do
LK
Allam
LK...I did what u said and still cant get any chanel ..it keep scrambled channel..what should i do?
Username: Bobbyc
Post Number: 9
LK, Sunday evening. Are there new keys? BC
Username: Bobbyc
Post Number: 10
LK, Sorry! I entered one wrong. Thanks any way. BC
Username: Lazeress
HI I still can't get my receiver its a Fortec lifetime Ultra I have flashed it with a STB updater ver 3.31 and used Al7bar FTA 050613_276_api(NTSC) after that I input the new Keys but I still can not get anything to work all I get is it to say scrambled or blocked station. What am I doing wrong
LK
KEY0 is active, changed Fri Aug 19 16:48:34 2005
KEY0: CF 2B 37 83 17 B2 CC 87 ...active
KEY1: C4 B1 B5 B5 DD 6E AF 81
same keys...no changes...and these work now!
Username: Bobbyc
Post Number: 11
LK, As usual, thanks, BC
Username: Lazeress
what does it mean when you say active key
Username: Lazeress
I have rebooted the receiver for over one min. and still no channels ?
LK
DISHNET KEYS Current
08-22-05 5:15pm EST
Key0: CF 2B 37 83 17 B2 CC 87
Key1: 74 0B 5F BD E6 04 29 1A ** Active
and then ALWAYS do a reboot/reset!
flam
I have been reading instructions about how to setup the Fortec Lifetime ULTRA. I have tried all that I have read. But like others, I still get the "Scrambled or bad channel" message. I have been through the instruction several times, making sure I've used the latest keys as given by LK this evening. LK can you verify the keys right now? I need help!! What am I doing wrong?
Username: Lazeress
flam I am in the same boat that you are I have a Fortec Lifetime ULTRA and get the same message can someone please walk us thur this ?
LK
Fortec key change method
1)With receiver hooked up to TV and satellite:
2)Press MENU on the remote control
3)Then right side arrow to CHANNEL EDIT
4)Go down to CODE, and press OK, and enter 1010 (could also be 1668 or 1688)
5)Then right side arrow to turn OFF, KEYCODE FUNCTION
6)Go to NAGRAVISION and press OK
7)Now press the right side arrow next to the OK button 11 times until it says ((DISH NETWORK))
8)Go down to KEY Number, then right side arrow to set to "00".
9)Go down to Key Data and enter the latest KEY with your remote control.
D5 6F BB 83 00 D8 B0 4E ...(example only)
10)Press OK, "you will see the STORE button blinking, when it stop you know that KEY Number "00" is saved.
11)Go up to the Key and Go to the right "1 time" (that will change key 00 to 01
12)Go Down and enter latest Key 01 change ..11 B1 AA A7 8B 9E 45 8B (example only)
13)Press OK, "you will see the STORE button blinking, when it stop you know that KEY Number "01" is saved.
14)Press EXIT once.
15)Then right side arrow to turn Code back "ON" and enter "1668" then EXIT, EXIT.
16)Lastly, on BACK of receiver (not remote)..power OFF,wait 1 minute ,power ON..this is a reset
Fortec buttons to use for letters
Sat=a
info=b
tv/radio=c
pause=d
audio=e
flam
LK, I did your instruction step by step verbatum. It still did not work. Let me give you some more info about my setup.
My dish is set to Sat. AMC-4. I am able to view/hear several FTA channels (Hope Chennal, Esperanza TV,ATN/ACN Service, 3ABN English, 3ABN Latino, LLBN, Peoples Network, KRUL Fox64 then some radio stations - 3ABN Radio, Radio 74,Lifetalk Radio). I am able to only hear the audio of the following: Court TV, MSNBC, Starz!, National Geographic, Fox News, Weather Channel, CNBC, AE History, AE Biography.
Does Dish Network carry anything on this Sat?
Also, the System Info on my unit is as follows:
Al7bar FTA Ultra
Al6bar - 2.76
Boot ver: 6.0
Jun. 13, 2005(Nt)
Is this what it should be?
One thing that I should note: When I was FLASHING the unit with the above version, it stopped a couple of times with the "Retry or Cancel" message. After pressing retry several times it continued to the end, then gave me the Download Complete message. Do you think that could have affected it in any way?
Is there anything that you could possibly think of why it does not function as it should?
Kilty_McBagpipe
Has anyone else using the Fortec Lifetime Ultra dish lost their PPV channels? I am able to get basically all of the other channels except the ppv and many other movie channels.
RANTone
yeah, me too. just came in to see if it happened to anyone else.
Username: Maple_leaf
Post Number: 751
No we have them you must done something wrong . Like got the wrong fta. LMAO .
ratman
-He didn't do nothing wrong except talking
to U Mable U FOOL.LMAO up your azz
having problem entering keys I am on nagra but were it should say dish it says
unknown 01 01 00
if I push the right arrow once it says
unknown 00 01 00
also every time someone post new key they put
**active dont see this on my screen no way to enter this in.
do I enter both keys in both dish areas or one in 01 01 00 or 00 01 00
LK
active means just that...its the ACTIVE key that was just/last changed..pushing the right arrow is changing it from Key0 to Key1...U will NOT see the word ACTIVE on the screen (LOL) and U do not enter/input that word.....U ONLY need to change the ACTIVE key, since thats the ONLY one that has changed....the other key should still be good from the last time U changed it,because it is NOT active and has not changed...
Now do U get it?...a little common sense goes a long ways!
Everybody has lost MANY channels to Nagra2 now...all PPV and PPV events are dead and gone to N2 now..after 31 August, U will only have the basic top 60 channels for a very short period of time..
LK
08-25-05 9:15am EST
Key0: E2 FC 16 1C D7 F5 1F 48 ** Active
Thank you
flam
Al7bar FTA Ultra
Al6bar - 2.76
Boot ver: 6.0
Jun. 13, 2005(Nt)
Username: Bobbyc
Post Number: 13
LK, As usual, Thanks, BC
Bc you can not get those on amc4 because it's differant encryption. (powervu)
Kilty_McBagpipe
Seriously, you guys still have your ppv channels... I probably broke the damn thing.
are these keys universal for all boxes-----i have a pansat 2700a and getting a bit frustrated with this whol nagra2 bs
what are the keys for today 25 of august
Missa
Does anyone know the new keys for today??? Please hook me up
Username: Bobbyc
Post Number: 14
missa, Run back about ten...or so messages. LK posted them this morning at about 11:40 A.M. BC
Username: Bobbyc
Post Number: 15
Missa. I mispoke....10:31 A.M. BC
greenhand
currently with dish network, 301 receiver, is there a card will make the receiver still work when contract is due? thanks.
Sat man 11
how do i over ride the parental controle with out changeing the password
LK
08-25-05 9:15am EST
i nead a password that will over ride the parental control without changeing the password or nowing it
LK
Load the bin/flash on it again..
LK
Thanks for the info on how to enter the keys it works great!
I dont seem to get any channels on 119 when I do a scan it fails got lots on 110 and the signal for 119 and 110 is at 98% you think I have a file missing?
Hannah
Anyone have new keys for today, August 26 dish just went down
Christa
Christa wants to know when the new keywords are so if anyone has them please give it to us.
Post Number: 767
Key1: FB 18 30 83 ED ED 5B AC ** Active
Thank You! Maple Leaf
Thank you Mapleleaf.
Have a great weekend!!!
greenhand
LK:
greenhand
HELP! the TP can not be fixed on #17, when exits from the setting, it is automatically to be changed into other #. Is this normal, or my Pansat 2500a has a problem? Thanks to anyone that can give me a clue. greenhand
Whitemouse
LK, my pansat 2500a was setup with bin file before (not by me). But by accident, I pressed the factory default key somedays ago. Does this mean that the bin was deleted by pressing that key? so, the bin file need to be reinstalled? If yes, what is the "appropriate loader" for doing that? Thanks, Whitemouse
any one has new codes???
white mouse
LK-I finally got it work. It is really not easy for a person at my level. Thanks, whitemouse
Bendsm
why I can't switch key code from 0 to 1...please help me
does anyone have the new codes?
Anyone hsa new keys for Aug 27?
yo wasup who got da codes we need deem hurry ^ there's something i want 2 watch!!!!!!!!!!!
does any person got da codes? you people is slow w/gettin these codes i've already looked so don't get no attitude w/ me cause I'm only 13 years old & i can score on people& roast on dem whish means I've always got an comeback HURRY ^W/THEM CODES!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!1
does any person got da codes? you people is slow w/gettin these codes i've already looked so don't get no attitude w/ me cause I'm only 13 years old HURRY UP W/THEM CODES!!!!!!!!!1
does any person got da codes? you people is slow w/gettin these codes i've already looked so don't get no attitude w/ me cause I'm only 13 years old HURRY UP W/THEM CODES!!!!!!!!!!!!!!!!!!
LK
U are the slow one...they were posted over 29 hours ago here in this same thread...LOOK ABOVE! (about 10 posts above yours here)...dah!.(oviously U didn't look or are not too bright)..if 13 then U shouldn't be here...either way, 13 year olds should be able to read and write!...and find something they want, thats STARING them right in the face..
crapshoot
F U C K . O F F .stupit kid
oops I'm sorry who ever this is but please give me the freaki'n keys and crapshoot why would you say that and I aint stupid I'm just ghetto dill with id yo my dad wants the keys okay.you don't even know me so how are you going 2 call me stupid.
Bendsm
does anyone have the new codes?????
And 4 this person LK I wasn't on the computer I was @ Venus Beach then went 2 my friends house and i just got home and my dad asked me 2 get the keys.....OH YEAH HOW DO YOU KNOW THAT i'M BRIGHT OR NOT JUST BY THE COMPUTER?
hello 2 who ever is Bendsm LK and crapshoot wont give me the codes no matter how nice I ask
B1TCH BOY
-A kid, got s_u_c_k your old mans dick...U
little B-A-S-T-A-R-D...U and your old man
are both f_u-c-ked in the head to let U
come on this sight...Both U and your dad are
two f_u_c-kin stupid to known whats going on,
Your dad needs his azz kicked and then
f_u_c_k in the O...Where is your B1tch mother
giving head to all the boys in the hood?
So kid f_u_c_k of or else I will have to put
my dick in your azz o to.
B1TCH BOY
-A KID-Are U a jirk or is it your father, or
both of u?...Kid U don't need to come on
this sight and talk crap...If U want, I
will stick my very large dick up your azz.
Your dad is a Dirt Ball for letting U on
this sight...He need me to f_u_c-k some
brains in his head. A kid where is the
mother out to BINGO meeting RINGO...Or
is she being screwed by all the boys in
the hood....Kid I want to stick my dick
in your azz and then screw your azz o
father for leting U come on this sight.
A kid does dad make U play with his balls?
U smart azz little c_o_c_k s_u_c_ker.
Post Number: 782
SMALL MINDS SMALL POST LMAO.
Iarry
MAPLE LEAF......SMALL DICK .
hi guys any one has new keys for dishnetwork ???
Anonymous2
Does anyone have the new dishnetwork keys??
hey - can anyone post instructions on how to use keymaster>? much thanks!
Username: Lucky4
Pt. buewell, Ontario Canada
hi ftaers does anyone have keys for aug 31/5
thanks lucky4
Username: Sharpes84
Post Number: 9
do we think that the locals wil go down too???i need to know for the nfl games any idea?
thanks
Username: Sharpes84
Post Number: 10
also pansat and fortec are the effected the same way?
LK
DISHNET KEYS Current 08-31-05
Key0: C0 25 28 E7 22 F5 1F 48 ** Active
Key1: 12 0C 9F BD E3 00 19 2A
Thank you LK. Have a great night!!!
LK i changed the keys like you said and i have picture but no sound. Are others having this problem?
supersmoothguy
i tried these keys and they did not work dont waste your time.
FUNWIZ
Key1: FB 18 30 83 ED ED 5B AC ** STILL ACTIVE
CNN STILL WORKING. IF CHANNEL DOES NOT COME UP AND RUN, IT HAS BEEN CHANGED OVER TO THE NEW SYSTEM. THIS IS PROBABLY THE LAST UNTIL A NEW FIX COMES OUT...... :-(
Username: 555
I CAN'T SEE PPV, HBO, PORNCHANNEL,DISCOVERY,ETC. IN DISHNETWORKS WHAT IS HAPPENNIG, MI LIFE TIME ULTRA SAY IN THE TV SCRAMBLED OR BAD CHANNEL
will we get the nfl games on their local channels? does anyone know yet?
Username: Whatareyoudoing
Post Number: 24
WANKER" WANKER" WANKER" WANKER" WANKER" WANKER"148 GTL-DXWANKER" WANKER" WANKER" WANKER" WANKER" WANKER"148GTL-DX WANKER" WANKER" WANKER" WANKER" WANKER" WANKER"148 GTL-DXWANKER" WANKER" WANKER" WANKER" WANKER" WANKER"148GTL-DX
WANKER" WANKER" WANKER" WANKER" WANKER" WANKER"148 GTL-DXWANKER" WANKER" WANKER" WANKER" WANKER" WANKER"148GTL-DX WANKER" WANKER" WANKER" WANKER" WANKER" WANKER"148 GTL-DXWANKER" WANKER" WANKER" WANKER" WANKER" WANKER"148GTL-DX WANKER" WANKER" WANKER" WANKER" WANKER" WANKER"148 GTL-DXWANKER" WANKER" WANKER" WANKER" WANKER"WANKER" WANKER" WANKER" WANKER" WANKER" WANKER"148 GTL-DXWANKER" WANKER" WANKER" WANKER" WANKER" WANKER" WANKER" WANKER" WANKER" WANKER" WANKER"148 GTL-DXWANKER" WANKER" WANKER" WANKER" WANKER" WANKER"148GTL-DX WANKER" WANKER" WANKER" WANKER" WANKER" WANKER"148 GTL-DXWANKER" WANKER" WANKER" WANKER" WANKER" WANKER"148GTL-DX
WANKER" WANKER" WANKER" WANKER" WANKER" WANKER"148 GTL-DXWANKER" WANKER" WANKER" WANKER" WANKER" WANKER"148GTL-DX WANKER" WANKER" WANKER" WANKER" WANKER" WANKER"148 GTL-DXWANKER" WANKER" WANKER" WANKER" WANKER" WANKER"148GTL-DX WANKER" WANKER" WANKER" WANKER" WANKER" WANKER"148 GTL-DXWANKER" WANKER" WANKER" WANKER" WANKER" WANKER"148GTL-DX WANKER" WANKER" WANKER" WANKER" WANKER" WANKER"148 GTL-DXWANKER" WANKER" WANKER" WANKER" WANKER" WANKER"148GTL-DX
MIKEY R
hey the guy above really must be a wanker. does anyone know if it is operation if the england vs. wales games is available on pansat
MICKY R
the sad thing he is a registreed memeber so it wont be that hard for the admin to track him down to his home state then crack a 2x4 over his head.
where aree thee keysss peoplee
Username: Ardvrk
Mississauga, Ontario Canada
anyone have the Digiwave7000 files
Don't Buy Pansat's
We will say this, we do not trust any of those factories, Fortec and Pansat, all run and owned by the same peoples, sharing and controlling the market.
Today is the fix for the Ultra, no, maybe in three weeks, yes ?
We visited Al7bar-soft1.com, checked if there was any new updates, no. We looked into the Technical Discsussion Forum. Keep in mind this is Fortec, only.
There was BlackList, making a statement that there will be no release for the Ultra until the clone issue was fixed, 2 to 3 weeks.
So, BL represents both, Fortec and Pansat, no fixes until the Pansat2700a generates more sales.
This well may be a hoax, but it did cause me to reflect on how all of us are controlled and manipulated by the factories, one of the same.
We recommend no further support of Fortec and Pansat and C00lsat.
We recommend a pci card, all the software is free without kissing azz, however not for everyone.
We recommend, a Dreambox, but not for everyone.
We have reservations in regards to the ViewSat, but possibly the best substitute
do not buy from efta.us
DO NOT BUY anything from efta.us or Pansat. efta.us is run by Pansat and they through their websites have distributed this file that kills all Pansats.
Mine is dead and I now have to buy another thanks to this SCAM!!!!!!!!!!!!!!!!
JDoc
Alright, I get quite a few channels. My friend hooked me up with keyz that worked pretty good, but is there any way to get the PPV channels or what?
DD
JDoc, can you share the "keyz" Pleeease
D
E1 FC 16 1C D7 F5 1F 48
FA 18 30 83 ED ED 5B AC
Username: 2700
I bought a Pansat 2700a. I would like to know how can i see the channels from dish networks, What software i need and procedure on how to do it. I'm new to this. Please help.
I bought a Pansat 2700a. I would like to know how can i see dish network channels. I have the dish hooked up. What else do i need.
for luisfavarez
read,download,read,download,read,download,install bin, cry help, receiver is dead
for luisfavarez
4 LuisFavarez
with the 2700 just goto al7bar .tk or al7bar .tc whichever one you want. Then get the bin file called X-87BL_050901_114_api.bin. Put this bin on your pansat with a current Blacklist loader which can also be found on these sites. You need to hook it up to your computer with the cable that hopefully came with the unit in order to put the bin file on there. After that just hook it back up to the dish and tv then go into the the menu and scan for channels. Now you have NAG1&2 up and running.
Username: Help_me
is there anyone with a pansat 2500a that is still able to see ppv sports and ppv movies?
FTA help
does anyone got new dish network keys for a multistar pantec ultra system?
