2700 or 3500 pansat getting fried like the 2500 A
knowledge
Are the newer versions from pansat getting fried? If not which one would be best to purchase?
Anonymous Anon
Either one will work fine. My 2300 is fine, up and running on NAG2 so I don't what is happening with other units, it seems like mainly 2500s are getting screwed over.
Praying 4 New Orleans
Does that mean my Multistar 2500 isn't any good now?
I live in BC Canada and have my dish pointed at Bell expressvu.
Any chance I can get my channels back?
Thanks.
Username: Slo_hand2
Post Number: 78
NO! the 2700 IS NOT getting fried, The 2700 is working fine the only one that HAD (Had) a problem which has be fixed is the KNOCK OFF 2500's and some older 2500's.
I say Again THE 2700 IS FINE!!!
Fast Hand 12
Say it again...
Username: Slo_hand2
Post Number: 80
say what?
FasterHand than b4
the 2700 is fine...
