New n2 bin for ultra that works with pansat
Username: Timscarlet
Dayton, Oh Usa
Post Number: 114
hello, here is a new bin that works with ultra and pansat, and the bin works with a pansat remote.
you can actually put a fortec bin on a pansat, and it will have menus just like a fortec, but can't use the pansat remote, only the fortec.
this bin has been safe for the fortec ultra, just the remote part has been changed to make the pansat remote work on it. it is safe, and i have been on since yesterday, still goin strong, tim
go to the webserver here:
[link removed]
Dayton, Oh Usa
Post Number: 115
this bin is the one to use, instead of the time bomb from blacklist. this was made for fortec, with a pansat remote. tim
Username: Stickman2004
hey tim first post on this site.do you think this bin will work with a pantec?
does this bin work with 2500a clones? i want to know cause i got one
Username: Fcukblklist
Post Number: 15
are steps you have to follow to load the bin?
PRFRMNJ
Tim - I had loaded "Al7bar FTA Ultra_050905_279_api(NTSC)" and it has been working good, but I saw there is a new bin for the Fortec Lifetime Ultra. I believe it to be the 287 bin. Do you recommend replacing the 279 with the 287? I've read just about all the threads here and I can't seem to find any info on this.
hangon
How do I load it on my (original Pansat 2500A).
I still have some channels and most of the music left on N1 bin files...Send me a link or something helpful...
Dayton, Oh Usa
Post Number: 116
the 287 bin should be for europe only i think, check it out. tim
PRFRMNJ
Tim - you are right. The 287 bin is for PAL system. There is however a 280 bin for NTCS...
Username: Taimak
SOME PLACE, MI USA
I did this new bin. I watched tv for about 10 min. and then my none clone Pansat 2500A went into a deep sleep. Won't fire up at all. Just thought that I would pass my misfortue to other people here.
