Silver Member Username: Camaro823British Colu... Canada Post Number: 206 Registered: Jun-05 | Ok this may sound stupid but I was just wondering, I have infinity door speakers and I was given a RF Component system, I don't want to use the speakers in the set because I feel my current speakers are better. I was wanting to know if there will be any problem if I use the RF tweeters that came with the set with my infinity speakers, will there be any problem ? |
Silver Member Username: ScubasteveCollege Park, MD Post Number: 512 Registered: May-05 | I'm not a big fan of infinity speakers, unless they're pefects. Even the kappa series speakers seem really flimsy and lightweight. You could try both of them out though, and see which ones sound better with the crossovers and the rockford tweeters. |
Gold Member Username: GlasswolfWisteria, Lane USA Post Number: 9915 Registered: Dec-03 | be careful doing this since the crossovers used are made specifically for the speakers provided, and each speaker will have a different response, and quite possibly a different impedance when dealing with tweeters, too. |
Silver Member Username: Camaro823British Colu... Canada Post Number: 208 Registered: Jun-05 | Ok Glass, I don't know what exactly to look for to see if this will be a problem. Could you tell me if this will be a problem ? Infinity speakers http://www.epinions.com/Infinity_652i_6_25__2_Way_Speaker__Main_Speaker_652i/dis play_~full_specs RF Component system http://www.epinions.com/614895_Rockford_Fosgate_5_25_Componenet_Speaker_System_F NP2514/display_~full_specs I don't know if thats anough info to give me a true answer but let me know what you think thanks |
