Inline battery fuse keeps blowing..
Username: Rzarector
Coquitlam, Bc Canada
Post Number: 650
i sold my system to my buddy ( mrd m1001, 2 alpine type 12" type r's) and he has blow his fuse to his battery twice.. i never had the problem.. setup is pretty much the same as i had it exept a bigger sealed box.. so what could it be? hes gona ahead and wired it solid to the battery :\ obviously a bad choice
Username: Carguy
Post Number: 4204
What was his fuse size? Tell him to take the cable out. If not, it could cause fire!
When a fuse blows, that's a good sign of a wire shorting somewhere.
Use a DMM to find the short. Never ever bypass the fuse.
Username: Rzarector
Post Number: 653
hmm i dont know the fuse size.. there all pretty much the same arent they ? that come in the 4 ga wire kits, whatever it is. so your guess is somehow the power wire got a short in it? could u expand on this DMM.. herd it mentioned alot but dont know exactly what it is,,, and price wise?? :-)
