Crossover rolloff question
ple
Is it in general true that the sharper the rolloff the better it is for crossover circuit i.e. 18dB/octave is better than say 12 or 6dB/octave?
Or do you prefer some rolloff so that some overlap happens to allow for smoother integration among speakers ( i hope i make some sense ).
The Alpine CDA 9815 has adjustable slopes of 6,12,18,24 dB/octave, the common choice is 12dB/octave, but in general how do you go about to decide?
Glass, your input is welcome.
Thanks
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 1723
the rolloff you want depends on the setup and the speakers.
I usually use about a 12dB/octave rolloff for mids, 18 to 24dB for tweeters, and 12 to 18dB for subs..
generally.
if you're rolling off from a 5.25" mid to a 15" sub, you want shallower, like 6dB for the mids, and 12dB for subs.. you want the rolloff overlaps to make up for the gaps in freq. since a mid will cut off around 100-150Hz or higher, and a sub usually starts at about 80Hz.
