Panasonic Deck.
CarzAudio!
I cant find the exact one at the moment but its kinda like this one but its all pure blue.
http://memimage.cardomain.net/member_images/6/web/162000-162999/162132_280.jpg
Thats the picture of it 50x4 now does any one know any special settings for this to maximize your Subs and Amps performance? Sblvl and like HPF etc etc. and mghz thanks alot much appreicated. http://www.futureshop.ca/catalog/proddetail.asp?sku_id=0665000FS10056718&CMP=OTC -Product_Feed&logon=&langid=EN# This i kinda like the one but not the one.
bombcaraudio
Also does things like http://www.knukonceptz.com/productMaster.cfm?Category=Installation%20Accessories # in the picture the terminal connectors the Black and Red one at the bottom and the first one at the topic make a big difference or a difference at all?
Username: Basshead86
Ocala, FL USA
Post Number: 941
if you have an amp, set the gain on the amp to the sub while the sub control on your HU is set at Zero. works the best that way, imo
put the HPF on your HU at about 100hz/12db slope. and the sub at 80hz or lower and i would recommend 18db slope, but you could set it to 12db slope if you prefer that better:-)
caraudio.
Gain on the sub? How do i set that sub doesnt have anything to set. Or do you mean the stuff on the amp. Is it alright to boost all the Base and Treble on the amp and then on the HU and increase th DB with the given amp? Would that just over do it? 1200 watt amp with 2 500 watt rms subs. 12inch
Ocala, FL USA
Post Number: 944
when you are setting the gain on the amp(the one that powers the subwoofer) do it while your subwoofer level is on Zero on your HU if your HU has a sub level feature. it isn't recommended to set it and turn it up past zero, b/c i think it adds bass boost to the sub which can distort it.
i wouldn't boost all the bass and treble on your amp and then again on your HU, you might drive the amp into clipping, and it may distort your subs eventually blowing them.
99Questions.
Also any one know how the Panasonic Deck that i have is ranked from 1-10?? Or Panasonic in all and what about Lanzar Heritage and Vibe? 1-10?
Ocala, FL USA
Post Number: 956
http://p079.ezboard.com/fcaraudiotalkfrm27.showMessage?topicID=48.topic
