Bronze Member Username: XkawnPost Number: 78 Registered: Jul-05 | suggestions please. they need to be small due to lack of room and also how should i wire them. thanks folkz......... |
Gold Member Username: GlasswolfWisteria, Lane USA Post Number: 9734 Registered: Dec-03 | PAC CF-1 is the fan ya want. wire it using a chassis ground, and use a relay for 12 volt power, using the remote trigger from the head unit as the signal source. |
Bronze Member Username: XkawnPost Number: 79 Registered: Jul-05 | hey glasswolf, should i get two of them?? one push and one pull??i think i'll try and drill a decent size whole on either side of the amp creat two tunnels (one for push, the other for pull) if thats plausible. this is the best price i could find... http://www.sonicelectronix.com/item_5283.html on sale for $28. thanks glass....... |
Gold Member Username: CarguyPost Number: 4150 Registered: Nov-04 | Kevin, you don't want to "push" air into the amp, unless it's aimed at the fins/heatsinks. After several months, you will have excessive dust inside the amp. Not good for something that gets really hot. Take a look inside your computer and you'll know what I mean. If you want two fans, then make both "pull" type. |
Bronze Member Username: XkawnPost Number: 80 Registered: Jul-05 | alright. thanks you guys. |
Gold Member Username: GlasswolfWisteria, Lane USA Post Number: 9747 Registered: Dec-03 | push-pull over the amp's cooling surface is a better idea, and old nylons from the GF or mom make great fan dust filters. |
Gold Member Username: CarguyPost Number: 4163 Registered: Nov-04 | Uhmmm, use the one from your gf. Trust me, you will like it better. |
Bronze Member Username: XkawnPost Number: 82 Registered: Jul-05 | they share the same one. i'll just rip off a piece and they'll never even notice.... |
Silver Member Username: FandimReno, Nevada United State... Post Number: 103 Registered: Jun-05 | If your mom and girlfriend wear the same nylons... Damn... that's just wrong on so many levels... |
