Phoenix Gold R15.0:1 for the RF T212D4?
Rei_hiker
Subject says it all. I was planning on just getting one sub. It's a DVC 4ohm each so wired in parallel would give the 2ohm load thus, 1000RMS.
Check it out and post your thoughts. Anything said is appreciated.
Rei_hiker
The sub also comes in 2ohms per Voice Coil.
I've been looking at this amp more and am not so sure about it anymore. I want a quality amp that is evenly matched with the quality of the sub. I need something in the $250 price range. (even if that be NEW on eBay)
