What size wire should i run
Username: Sponge2099
Windsor, On Canada
My total system out put is about 1400watts rms, and i m trying to figure out which wire would be better to run my system becasue there is going to be 2 amps (1-1000Rms and 1-400rms), what size wire should i run and how should i wire it.
Any help would be great
thanks
Username: Glasswolf
Wisteria, Lane USA
Post Number: 8550
1/0ga from the battery
4ga to each amp from a d-block at the amp location
Username: Beaverhunter
Kc, Mo Usa
i would say the same but i would def get a cap
Username: Alias747
MN
Post Number: 557
No, you don't need a cap, they are a useless waste of money. You will need a HO Alternator if you are still running a stock one, that's quite a bit of power you are pulling there.
Windsor, On Canada
I m going to be putting on a Ho alternator with the install i was just unsure what wire to run becasue the car audio shop around my house said that 4 guage would work and 2 would be better
Username: Mrmbq
Portland, OR USA
Post Number: 10
4 guage wire would work from the distribution block to the amplifiers, but not from the battery to the distribution block. 4 guage is not suitable as a main power wire in your system as it will not be able to deliver the amount of current that your amps will need. 1/0 is a must. And by the way, Issac is right, don't waste your time/money on a cap.
those digital capacitors are just a very expensive volt meter in my opinion
