Mid bass problems
robert r d r d
one of my pheonix gold 6x9 octane R's isnt working right it still produces music and the tweeter works but the cone wont move and wont produce bass
anyone know why that would happen ?
it sounds fine no static or anything
Username: Illuminator
Post Number: 1523
You probably blew the woofer...
Username: Mixneffect
Orangevale, Ca. USA
Post Number: 324
We need more info:
Do you really know how to wire up a stereo system or did you just try it anyways?
Is there an external cross-over involved?
Are the woofer tinsel leads touching the tweeter/midrange wiring?
Do you have a cross-over setting on your amp/HU, and is it set to cut off low frequencies?
robert r d r d
i took out the speaker and yea i did blow it ... the cone wont push down its stuck
wat causes this and if its 75/150 w and my boss head unit is ??/80 why would that happen?
Username: Riebread77
Post Number: 611
clipping...you drove your headunit's amplifier too high...instead of a normal sine wave, it produced a square wave...it damages speakers and eventually leads them to blowing...more speakers blow from amplifier clipping than actually feeding them too much power.
