All i can say is that the Acura/Honda radio's are a BI**H. If you really want to tackle it, here's what you do: There are 2 screws that hold the factory radio in. The thing is that they are BEHIND the radio, BEHIND the dash. You can try to get them with a regular philips, but when i did mine in my '88 legend, i had to use, get this, an AIR CHISEL to spin it out. After you get these out, it's easy. Pull your shifter into "L" or reverse on a manual and slide the radio out of it's place. Hope this works for you.
Bassman
How do I take out the steaeo of a 1984 Cadillac w/o tearing up the dash? I found the two in a/c vents but there is two more that I can't find. Please help
