Other factors come into play, what speakers will you be using, car speakers, are outboard amps involved, etc. Now stop being so nasty, you came in here asking for help as an unregistered guest and you act like a troll.
Jexx already told you how, now begone!
john j
Geeez, Jexx said "you need a power supply" then what? how do I do the connections?
Come on, can you guys please be smarter and indicate me how I need to proceed step by step? I don't undertsand, why is that so hard to do?
Step by step will always lead to tedious explanations....something I tend to avoid...
10 amps will run nearly any headunit with all four speakers hooked up to the internal amp. Yellow+Red wires from headunit need to be hooked up to the Positive terminal on the power supply.
Black wire from headunit goes to negative terminal on power supply.
Speakers are as follows:
Each color represents a pair of wires, one (+) and one (-) for each speaker...
God bless my brain...I am still confused! I am starting to worry about it !
Is that picture of a Car CD Player ?? So I get the power supply, connect the left and right front cables to the right speaker and the right and left rear to the left speaker? Will this sound in stereo?
Man, I guest I will just buy a regular home easy to use CDP
