Post Number: 3659 Registered: Dec-03
Posted on You need high level inputs on your amp. And if it is a stand alone car amp, you need a switch to turn it on. Is the amp turning on? Either way you really should post this inquiry in the Car Audio section. This is the HOME AUDIO section. |
