Alpine Mrd-m1000 help
Hey. I just installed my amp the other day brand new out of the box. I have it hooked up to an ma audio 1500xl sub and an alpine cda-9835 hu. The amp is connected to a cap and was working fine, but then it just shut off. The digital readout on the cap and amp read anywhere from 12-14 volts before it shut off consistently. Now neither the cap or amp will turn on. What should i do? if it helps, both the cap and amp are grounded in the same location which is about 3-6 inches from a smaller amp for my speakers. and since then the belt around my alternator has snapped and the battery light on the dash won't turn off.
Username: Carguy
Post Number: 4025
Sounds like you over taxed your stock alternator. Get your car tested properly from shops like PetShop boys.
There's a chance you might have to replace both the battery and alternator.
Just curious, did you get dimming lights before all that happened?
yes i did have dimming lights before it happened. also the rpm guage isn't working and the check oil light keeps blinking (car is a 1997 vw td golf if it matters)
