I am putting in a system for a friend he has a 1996 nissan altima i have everything hookedup up except the remote wire. this is because the wiring harness doesnt have a remote wire coming from it so i need a wiring diagram for a 1996 nissan altima if you can help me out thanks.
rideredder
if you have a circuit tester, go to the fuse panel and find a fuse that gets juice when the key is foward and when the car is started but doesen't get juice when the key is off. take your remote wire and just wrap the wire around the prongs on the fuse and plug it back in. then the amp should turn on.
