Annoying buzz from speakers,Help!
Username: Nixvet
DLP front projector, Onkyo amp. I'm running the video from my dvd player to the projector...av cable. The 2 sound av's are to my onkyo amp. Sound and picture quality are terrific...but an annoying buzz from the speakers when I turn on the projector. I tried plugging projector into other outlets to no avail. Do I need a filter?
Thanks in advance...
nixvet
Username: Ziggyzoggyoioi
Outside Philadelphia, PA
Post Number: 123
If you have a cable box in the system, you may need a ground loop isolator. To see if that's the problem, try uhooking your cable line from the wall.
