OHM ISSUE
Username: Alastaka
Post Number: 84
ok im going with a dual voice coil (4 ohms each) sub is there any possible way to wire this down to a 1 ohm load with out adding another sub and useing a mono block amp. i know they make subs that are DVC 2ohm but its 210 less buying this one and i dont really wanna pay more
zook
no only 2 and 8
Username: Thugunlimitedx
Post Number: 17
if its 2 subs u can wire it down to 1ohm but if its 1 sub ur only goin 2 get a 2ohm load 1 sub http://www.rockfordfosgate.com/rftech/wiringwizard.asp?WoofQty=1+woofer&WoofImp= Dual+Voice+Coil+-+4+ohms+x+2&image.x=19&image.y=4 2 subshttp://www.rockfordfosgate.com/rftech/wiringwizard.asp?WoofQty=2+woofers&WoofImp =Dual+Voice+Coil+-+4+ohms+x+2&image.x=17&image.y=11
Username: Alastaka
Post Number: 86
yeah thanks thats what i figured but i didnt know if there was some way to pull it off with only the one sub
