When to install the fuse
Username: Pikesh
Post Number: 69
hi guys . i have all the wiring done in my car for the system... only question i have is that connecting the power cable.. first i will disconnect the (-) terminical connect the power cable to + and then give all the connections to amp...then going back to the hood i will connect my awg fuse and then connect negatie terminal back.. then everything should fine i hope... lol i am newbie soo just needed lil instructions wen to connect power cable n precautions tell me if i am right
Username: Pikesh
Post Number: 70
ne one can help me on his easy silly question lol
Username: Infinity_addict
Santa Rosa, California USA
Post Number: 124
yah, that's all good bro.
